Shift Points on 06 HEMI!!
Old Apr 30, 2008 | 09:06 PM
ssgdick's Avatar
ssgdick
Default Shift Points on 06 HEMI!!
Does anyone have any recommendations on what to set the shift points at onthe HEMI. I have the Triple Dog Gas Downloader and it allows me to change the shift points. Just curious if anyone has any suggestions.
Old Apr 30, 2008 | 10:10 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Default RE: Shift Points on 06 HEMI!!
Here is what you do...
Don't mess with the shift points...
The programmer allows you to adjust the shift points in the event you do any heads/cam work on your engine that will ALLOW the higher shift points. If you increase them now, you take a good chance at throwing a rod or something even worse. The only thing you should be messing with is the actual program to upload and if you have different tires than the stock on, change the tires size for the speedo adjustment.
Old Apr 30, 2008 | 10:25 PM
ssgdick's Avatar
ssgdick
That is what I figured, but I figured I would ask. I also knew that I would get an answer on here. Once, again thanks for the input and advice.
