160 thermostat for 04 dodge ram
Old May 1, 2008 | 06:39 PM
Yellow Runner's Avatar
Yellow Runner
Default 160 thermostat for 04 dodge ram
I had always been lookn for a 180 degree thermostat for my 4.7 but never could find one so i went ad bought a 160 degree thermostat for a 99 dodge ram 5.9l and put it in there nd guess what, it works and fits and it runs cooler alot cooler i can feel alot more power and i still have awsome heating, thought id share wit yall just incase yall wanted the info.
Old May 1, 2008 | 07:42 PM
MikeHTally's Avatar
MikeHTally
Default RE: 160 thermostat for 04 dodge ram
You may start getting some CELs.
Old May 1, 2008 | 09:25 PM
casper3380's Avatar
casper3380
thats too low for my comfort, being that (if you use it) normal oil doesnt start lubricating properly until 150 F. too low for my blood. hope it works for you m8.
Old May 2, 2008 | 04:03 AM
Mr Edison's Avatar
Mr Edison
Most modern vehicles will not perform well because the engine is running too cold and the ECU will keep system in the default (cold) mode giving you poor mileage and excessive engine wear because oil never gets hot enough to burn off contaminates. If you are having overheating problems get that fixed and install the correct thermostat.
Old May 2, 2008 | 04:59 AM
RamItOne's Avatar
RamItOne
ORIGINAL: Yellow Runner
http://store.summitracing.com/egnsea...p;autoview=sku
Old May 2, 2008 | 05:03 AM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
you should get 4.56 gears installed now too.
Old May 2, 2008 | 10:42 AM
ramracing4.7ltr's Avatar
ramracing4.7ltr
i also have the 4.7 ltr and looked forever forthe 180 thermostat as well, lol just last night i found it through jet performance and ordred it,also where i got my chip. but with a 180 stat , plus this liquid cool stuff (you add to your regular coolant) you can buy from checkers , should run alot cooler now.
