SPARK PLUGS
hey, I want to change the spark plugs in my 03 ram 1500 w/HEMI, but I cant get to the plug in the back on the drivers side. The master cylinder is right on top of it. It would be great and a big help if anyone had any tips. also I am not the most mechanicly inclined, so please don't tell me I have to pull out the engine or take of a fender or something like that.
No, you just have to be a contortionist. A flex spark plug socket helps. Use short wobble extensions. Most people go in under and behind the master cylinder. Just in case, remember -- there are sixteen plugs.
I took the front tires off and dropped the front end on the ground - that made it considerably easier to get to the back - just from a height perspective.
Take the air hat off - it's just a couple bolts and makes things waaay easier to get to.A short extension and a ratchet - it wasn't a big deal.
pm horseapples, he changes them at the track and apparently does it within 20-30 minutes...
Trending Topics
I just got through doing them today on mine... and total time to take everything apart and put it all back together again was about 2 1/2 hours for me with all the right tools. Used the Bosch 2 plats because nobody had anything else around me and to top it off I still had to go to 2 different stores to end up with the total of the 16 plugs. I had 56000 miles on the originals and I would say they could have lasted quite a bit longer because they looked fine, used but fine. I think Chrysler is just trying to scam us with the 30,000 miles required change. And honestly I cant tell any difference after the change in performance... so whatever. I say unless your having spark issues, dont bother changing them till at least 60k miles or your just wasting time, effort and money.
ORIGINAL: vipersforsale
it is not reccomended that you use platinums in the hemi as they can ping... but the reason for the 30k rule is because all trucks are used differently. A daily driver truck or a truck that cruises along the highway arent going to need much changing but a truck that is towing often and working hard need the changes more often... my plugs were pretty bad at 30K but i tow at least once a week and haul things rather often as well... its all about the chores the truck is doing..
