KN Air Filter problems
Old May 12, 2008 | 08:29 PM
raminator08's Avatar
raminator08
Default KN Air Filter problems
i recently installed a full cold air intake that i got off ebay and it came with a kn air filter.this is what i bought- http://cgi.ebay.com/ebaymotors/07-DO...3756.m20.l1116 I put everything together just fine and drove around with it yesterday. When i got home, i opened my hood to see how everything was and i saw that my filter that was near the wheel well had come off. it was still in there but had slipped off the pipe.I dont when it came off but im not sure i was suppose to be driving around without one.I know i clamped it down good but to be sure it dont happen again, Does anyone know the best way to keep it on?
Old May 12, 2008 | 08:40 PM
UP_Boilermaker's Avatar
UP_Boilermaker
Default RE: KN Air Filter problems
If the surface the filter is clamping to is rather smooth or slick, just hit it with a little belt dressing. That should tack it up enough so the filter won't slip off again.
Old May 12, 2008 | 08:59 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
sheet metal screw through the clamp and air hose. use some sort of silicone or sealant around the screw.
Old May 12, 2008 | 09:34 PM
raminator08
ORIGINAL: xfeejayx
i dont think you understood me. Im talking about the actual K&N air filter slipping off the intake pipe, not the intake hose.
Also, will double sided tape work? Im not sure that it will hold since everything under the hood gets hot and might melt it.
Old May 12, 2008 | 10:17 PM
HammerZ71's Avatar
HammerZ71
This seems to bea very common thing with the "ebay" CAI's people are buying, you are the 3rd or 4th person who has stated this in the past week or so.
How about a pic so we can see exactly what you are talking about...
Old May 12, 2008 | 11:14 PM
raminator08
ORIGINAL: HammerZ71
well if you look on the picture from the ebay link i have above, you can see how the pipe curves downward right next to the radiator.the k&n attaches there to pipewith a clamp and hangs downward so that probably explains why it falls off so easy. How do i prevent it from slipping off?
Old May 12, 2008 | 11:28 PM
kniner's Avatar
kniner
I would take the down tube off and scuff the end with a file or sand paper real good. Then for extra clamping use the belt dressing too.
Old May 12, 2008 | 11:48 PM
raminator08
hmmm, im gonna think about the belt dressing and sanding but i want to be xtra careful, any other suggestions besides making the pipe have more grip?
Old May 13, 2008 | 06:52 AM
xfeejayx's Avatar
xfeejayx
ORIGINAL: raminator08
ORIGINAL: xfeejayx
put it through the clamp, or any part of the filter body that goes over or inside the air tube, and through the tube itself. back it out, take off the filter and get the drilled pieces of metal out. replace filter, squirt sealant/silicone where the screw will go (around the hole you already made), then run it down again. and i said sheet metal screw so you don't have to worry about the drilling and such, it'll do it for you. you'd literaly be screwing the filter and air pipe together.
am i misunderstanding how the filter and pipe attach? if so, then we are def going to need a pic, cuz most filters attach the way I'm imagining this one.
Old May 13, 2008 | 08:10 AM
HammerZ71's Avatar
HammerZ71
Scuff it up and you could also drill a small hole through the clamp for a little "set screw" or two.
