? about tire size 305 50 20's
Old May 14, 2008 | 01:18 PM
HogHunter's Avatar
HogHunter
Default ? about tire size 305 50 20's
Im wanting to order a set of 305 50 20 terra grapplers and would like some info to make sure they will fit. My dodge is a 4x2 with a 3 inch suspension lift.
thanks
jimmy
Old May 14, 2008 | 01:53 PM
kenihemi's Avatar
kenihemi
Default RE: ? about tire size 305 50 20's
I just put on Terra Grapplers LT305/55R20. Same diameter as my stock 275/60R20's (33" off the rim).
No rubbing.
Yours will be 1" shorter so I don't see any problem.
Old May 15, 2008 | 12:02 AM
John  M's Avatar
John M
They'll fit fine and you'll get a better effective gear ratio too.
Old May 15, 2008 | 05:42 AM
Brother Rob's Avatar
Brother Rob
Retired Moderator
I'm running the same size, but Kumho tires w/ Boze 20"s. No rubbing, no buffing.
Old May 15, 2008 | 08:33 AM
RedneckDodge86's Avatar
RedneckDodge86
Hoghunter what brand is that brush guard?
Old May 15, 2008 | 11:58 AM
mmstar23's Avatar
mmstar23
i have 305/50R20. no rubbing. like mentioned above, get 305/55R20's i think my tires are way too small and im going with 35's soon
Old May 15, 2008 | 03:23 PM
justntexas07's Avatar
justntexas07
My setup did rub stock but after the 2.5" leveling kit no problems.
Old May 15, 2008 | 09:13 PM
HogHunter's Avatar
HogHunter
RedneckDodge86 the grill guard is made by Gage
Old May 25, 2008 | 01:22 AM
HogHunter's Avatar
HogHunter
Well i changed my mind about the 305 50 20's and picked up a set of 18 x 9's with 325/60/18's and im glad i made this choice. i really like the look
Old May 25, 2008 | 05:12 AM
Brother Rob
Retired Moderator
Looking good, HogHunter. You're a bit higher than my truck. You're definately not gonna have to worry about any rubs. Besides, with the lower profile tire, I think there's only about 1/4" difference between the stock 17's with higher profile...meaning the whole wheel/tire height is not much different.
