check engine
Old May 14, 2008 | 06:06 PM
La_iNsaNe's Avatar
La_iNsaNe
Default check engine
I've got an 04 Quad Hemi Ram that looses power. When this happens the electrical light flashes and the check engine light goes on. Then I turn it off and back on the electrical light stays off but the check engine light stays on. After some time the check engine light turns off. If someone has an idea I would appreciate the help.
Old May 14, 2008 | 06:13 PM
HammerZ71's Avatar
HammerZ71
Default RE: check engine
Stop by your local Auto Zone, or just about any other chain auto parts store. They'll pull the code for you for free. Then give us the code here and we should be able to tell you what's up.
Unless you have a code reader or tuner of your own, then you can pull the code yourself...
Old May 14, 2008 | 06:16 PM
La_iNsaNe's Avatar
La_iNsaNe
I'll do that. Thanks
Old May 14, 2008 | 06:29 PM
irelandshemi's Avatar
irelandshemi
i had the same problem and when i ran it it said something like an evaporater core
Old May 14, 2008 | 06:57 PM
La_iNsaNe's Avatar
La_iNsaNe
Got a code reading P2175 TAC airflow
Old May 14, 2008 | 07:05 PM
HammerZ71's Avatar
HammerZ71
Sounds to me like the throttle body is clogged up pretty good, take off your air intake to get to it, clean it real good with some brake cleaner. I believe there is a "DIY" on it. I'll try to find it and give you a link...
Here 'ya go, should fix you right up...
https://dodgeforum.com/m_1050644/tm.htm
Old May 14, 2008 | 07:12 PM
La_iNsaNe's Avatar
La_iNsaNe
thanks I'll give it a try
Old May 15, 2008 | 12:16 PM
La_iNsaNe's Avatar
La_iNsaNe
looks like that worked. thanks again
