RPM fluctuations while stopped
Old May 16, 2008 | 09:43 AM
OSUBuckeye08's Avatar
OSUBuckeye08
Default RPM fluctuations while stopped
Hey guys,
I'm new here and a new Ram owner. Its a 2002 1500 V8 5.9L. Anyways, just recently when i'm stopped at a light my RPM will fluctuate. I'm not sure at the moment exactly how much because i'm stuck in the office but it is at least by a couple hundred. Anyone have any ideas? Thanks a lot.
Old May 16, 2008 | 10:20 AM
KrazyBrian's Avatar
KrazyBrian
Default RE: RPM fluctuations while stopped
Idle Air Controller, it's mounted on the throttle body next to the throttle, take it out and clean it (Don't take it apart) also clean out the throttle body while you are there.
If that doesn't fix it, replace it
edit, if i recall it's held in by 2 torx bolts, and is on the back of the throttlebody where you can't see crap, also don't over-tighten it, the throttle body is only aluminum
Old May 16, 2008 | 07:11 PM
rtmtrrdr's Avatar
rtmtrrdr
my 4.7 does the same thing
