will these tires fit???
Old May 22, 2008 | 08:32 PM
trx450's Avatar
trx450
Default will these tires fit???
general grabber uhp, there goin on a 2007 dodge ram 4x4 qc
tire size is 305/40/R24(it says the diameter is 33"), and also how many inches is the stock tire?
Old May 22, 2008 | 09:50 PM
ssgdick's Avatar
ssgdick
Default RE: will these tires fit???
I can't state for sure that they will fit. If your stocks are on 20 in rims, I believe they are like 32.9 in. Anyone can correct me if I am wrong. It sounds like they will fit if the overall diameter is the same. Only makes sense. Sorry, not more help.
Old May 22, 2008 | 09:55 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
ORIGINAL: ssgdick
+1
math on stock size (275/60-20) works out to 33" tire. your new 33"s should fit fine in the well, you might get just a little bit of rub when you lock the steering in one direction or the other if the backspacing isn't right.
but a little bit of rubbing at full turn won't really hurt anything since you're only going 2 mph when you do that. look into a front level kit to solve the rub if it does.
Old May 23, 2008 | 08:47 PM
trx450's Avatar
trx450
thanks for the help ill post some pics im picking them up tommorw
Old May 23, 2008 | 09:28 PM
ivaskaj's Avatar
ivaskaj
Same diameter, but you would be going from a stock width of 10.8 inches up to 12" wide. With the right backspace, you will be fine with no rubing.
