lift a 2wheel drive
Old May 26, 2008 | 02:24 AM
kicker417's Avatar
kicker417
Default lift a 2wheel drive
Hello everybody I have a 2007 Quad Cab 2wheel drive with the MDS Hemi and was wonderin how much and where could i find a kit to lift the front of my truck so it can be level to the back and what is the biggest size tire i could put under there
Old May 26, 2008 | 02:44 AM
irelandshemi's Avatar
irelandshemi
Default RE: lift a 2wheel drive
im assuming they make them them for the 07's but a leveling kit is what i would recomment to level the front to the back
Old May 26, 2008 | 08:35 AM
Whitelightning08's Avatar
Whitelightning08
My 08 hemi has a 1.5" lift on the front and that is still slightly raked on the front but not enough that you can really tell. If you go any higher than that you will have to replace the control arms which is starting to enpensive. Even at a 1.5" lift I had to replace the shocks the rearend is still stock lift. I put 315/55/20 Nitto Terra Grapplers and this thing looks pretty bad*ss. Its1.18" wider than stock and .22" taller than stock. I need to put a picture up ofmy truck so you can see what I'm talking about.
Old May 26, 2008 | 08:38 AM
HammerZ71's Avatar
HammerZ71
To hold down the expense, look for a level kit that comes with shock relocation brackets, allowing you to retain your stock shocks. Might cost a few dollars more for the kit, but will cost you much less in the long run...
Old May 26, 2008 | 08:56 AM
RamItOne's Avatar
RamItOne
315 55 20 is 33.6" x 12.4" vs the stock 33" x 10.8 inch
how long were you rolling on the stockers? What kind of mpg decrease did you see?
If you screw up and get a 2.5 or higher lift and it sits too high you can always add a leaf to the rear or date a fat chick to weigh the front down.
Old May 26, 2008 | 09:08 AM
Whitelightning08
I had the stocks on for about 100 miles and changed over to the 315/55/20s so i never really had a chance to see if there was a difference. But this breakin period is what i'm waiting for to end so I can get true numbers. As far as a fat chick ridin shotgun for levelin purposes my truck came with a minimum cabin weight allowance so I don't think it'll work, for me, personally anyways.
Old May 26, 2008 | 10:04 AM
Thunderroad23's Avatar
Thunderroad23
just go big and get a 6 susp 3 body and slap some 37s under there.
C:\Documents and Settings\Owner.A481A65B15814DE\Desktop\Kevin\BA 2wd.jpg
Old May 26, 2008 | 05:28 PM
kicker417's Avatar
kicker417
how much is the price the for the 1.5 lift and u think maybe you could put some pictures of it. And yeah i did wanted to lift it up that high but i bet 6 inch lift with 3inch body lift would be alot of $$$$$$$$$$
Old May 26, 2008 | 05:33 PM
Thunderroad23
you can get a body lift for 330, Rough Country 3in lift spindles for about 220, 2 1/2in spacer from ebay and 2in blocks. slammed1 sells a package deal 6in for about 600. slammed1.com
Old May 26, 2008 | 05:47 PM
MikeHTally's Avatar
MikeHTally
My '03 got a 2 1/2" level kit about six months ago. No issues with suspension components at all. Maybe the newer ones are different?
