3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Another thing that will make life easier when changing plugs is to remove the EGR tube that runs directly over the passengers valve cover. Remove the 2 8mm bolts that secure the tube at the valve and one clip at the intake, behind the throttle body. The gasket is reuseable as long as you dont tear it up, but its a tough fiber type gasket, I have done many and never torn the gasket
