Will my new Tires Rub? Pics inside!
Old Jun 3, 2008 | 05:53 PM
HogHunter's Avatar
HogHunter
Default Will my new Tires Rub? Pics inside!
ok,
i have a set of 325 60 18s on truck now. ive ordered a set of 325 65 18 terra grapplers for a little more height, however by looking at my current setup will i rub? pics show my 325 60 18's.
thanks
Old Jun 3, 2008 | 09:06 PM
sos's Avatar
sos
Default RE: Will my new Tires Rub? Pics inside!
Looks like you are going to be REAL close. Do your tires ever rub now when you are on rough roads or offroad? I can't believe your current ones don't ever hit considering that parked they are within a fraction of an inch.
Old Jun 3, 2008 | 09:10 PM
dodgenitto's Avatar
dodgenitto
If you haven't already cranked on the torsion bars then I would if I were you! Or You can put new torsion keys in all together!
Your current tires are 33.4" and the ones you want to put on are 34.6" in diameter! By the looks of it you will rub! SO crank on the torsion bars and you should be able to clear them!
Old Jun 3, 2008 | 09:18 PM
HogHunter's Avatar
HogHunter
I have Zero rubing currently, and know it will be very tight with the 325 65's.
the top pic i have wheel turned all the way to the left and the bottom its turned all the way to the right. Adding an additional 3 inch body lift wouldnt help, would it?
Old Jun 3, 2008 | 09:31 PM
dodgenitto's Avatar
dodgenitto
ORIGINAL: HogHunter
Sure it would help, But why do that for $700-$1000 installed when you can crank the Torsion bars in 15-20 minutes with a jack and a socket set or big wrench for free!
Old Jun 3, 2008 | 09:34 PM
HammerZ71's Avatar
HammerZ71
You don't need the body lift to fit a 34" tire. A simple crank of the torsion key bolts should give you the height you need. Might tighten the feel of the front end up a smidge, but you'll clear those bigger meats.
Old Jun 3, 2008 | 09:35 PM
sos's Avatar
sos
If you are looking for height, why are you going with tires that are only going to give you about 1/2 of added height?
Old Jun 3, 2008 | 10:07 PM
HogHunter's Avatar
HogHunter
got a great deal on the 325 65's and there height is 34.63 while the 325 60's have a diameter of 33.35 giving me little more than an inch.
Old Jun 3, 2008 | 10:12 PM
sos's Avatar
sos
Well you can't turn down a good deal Your height gain will only be half of the difference though because although your diameter increases by an inch or so, the radius increases by half that, and your wheels are mounted at the center.
Old Jun 3, 2008 | 10:13 PM
dodgenitto's Avatar
dodgenitto
ORIGINAL: HogHunter
They might be 1 more inch in diameter, but that is only 1/2" higher that your truck will sit! the other 1/2" will just take up more room in the wheel well!
