02 ram 1500 4.7L with AC problems
its been hot and my AC is starting to act up on me. Its been fine up until about a week ago. When you first start the truck and run the AC ( on MAX) it gets very cold in the truck and then for some reason ( not time specific) the clutch disengages and it will take a very long time before the clutch re-ingages ( sometimes the truck will get HOT inside) before it comes back on. I dont think the problem in low freon but I have no checked with a set of gauges. What are the low and high side pressures when running? Any thoughts on what might be the problem? I was wondeirng if the pressure switch might be causing the problem. Condensor fan works fine, no fuses blown either.
Your AC condensor is NOT mounted to your radiator. Your AC condensor is located to the Right side of the radiator with its own seperate ELECTRIC FAN mounted to it. Many people confuese that as a transmission cooler... its NOT. Your Clutch fan has NOTHING to do with your AC.
There is a TSB for that electric fan. They will replace it with a 2003+ Electric fan that is better suited for the AC cooling system.
I had my 2002 4.7L AC fan replaced under warranty.
SPEED SAFE, AIR RAM
SPEED SAFE, AIR RAM
ORIGINAL: AIR RAM
SPEED SAFE, AIR RAM
SPEED SAFE, AIR RAM
Guys, The fan on the side does come on. Why replace it? Will they still replace it under waranty with 65K miles> What is the TSB number and why would that be casuing my problems.
Air Ram,
When I said clutch I mean the compressor clutch. The Condensor fan does come on and I know it is to the driver side of the radiator becuase I had the problem with fuse blowing int he winter time and had that issue fixed.
