sounds like....
Old Jun 25, 2008 | 01:50 AM
Romeosoldier03's Avatar
Romeosoldier03
Default sounds like....
my wierd noise I have as wierd as it sounds...it sounds like "marbles, or coins dropped into a glass jar" lol....sounds just like that when accelerating after my truck has warmed up...again...just had headers/y pipe installd....
Old Jun 25, 2008 | 07:51 AM
HammerZ71's Avatar
HammerZ71
Default RE: sounds like....
Did you check those bolts, sounds to me like you might have a couple of loose ones. If you (or the place you used to install them) did not re-tighten them when they were hot, they'll work right out of that soft aluminum head.
Check 'em and if any are loose, run the truck around town for about 20 mins. then snug them up with a wrench (and be very carefull not to burn yourself)...
Old Jun 25, 2008 | 08:12 AM
#Red's Avatar
#Red
That is what it sounds like to me also. Good luck. Red
Old Jun 25, 2008 | 08:19 AM
MEINEKEMAN1's Avatar
MEINEKEMAN1
Agreed.
Old Jun 25, 2008 | 09:14 AM
Romeosoldier03
i'll do it today...i was hoping that was wat it is....thanks
Old Jun 25, 2008 | 02:44 PM
HammerZ71's Avatar
HammerZ71
Oh Romeo, just a thought, check the other end, it could also be an exhaust leak at the collector end as well or basically any place that they welded/bolted anything together.
Anybody can boo-boo a weld or joint very easily...
Old Jun 27, 2008 | 02:55 AM
daytona1680's Avatar
daytona1680
Sounds like a header leak...did you use the cheap *** gaskets they send with the headers, or did you get some good gaskets?
