Fusebox diagram
Old Jun 29, 2008 | 11:47 AM
jstmahoney's Avatar
jstmahoney
Default Fusebox diagram
I tried to do the thing with the wire and fuses, to run the fogs and the high beams together, and when i did it like it wasdoneon the pics i found, it didn't work. So i took the wire off and put it back the way it was, and now my fogs won't work at all. I was wondering if anyone has a fuse box diagram, so i can figure out what fuse 63 and 73 go to. Could the fuse(s)be burnt out?
Old Jun 29, 2008 | 12:46 PM
kenihemi's Avatar
kenihemi
Default RE: Fusebox diagram
Its not that easy. A diagram of the fusebox will not help.
It will pretty much show you the same thing as under the lid.
Test those fuses with a meter, yes one or both could be blown.
Old Jun 30, 2008 | 02:21 PM
jstmahoney's Avatar
jstmahoney
Thanks. I figured it out. I didn't even look on the fusebox cover! The diagram is on that! But I fugured out the problem, and i got it wired so that the highbeams will work with the foglights
