*PICS* Finally finished RCSB sub install
Old Jul 13, 2008 | 05:54 PM
stoploss's Avatar
stoploss
Default RE: *PICS* Finally finished RCSB sub install
ORIGINAL: standard85
thats not carpet, is it? and if it is spray on bedliner how did you apply it? thanks
Correct, not carpet. It is ArmorThane which is similar to Rhino liner or Line-X: http://www.armorthane.com/armorthane.cfm
It was professionally sprayed on by an ArmorThane dealer. Its sprayed directly on the MDF, I only prepped the MDF with 220 grit prior to spraying.
I originally wanted Line-X, but the local Line-X dealer wanted $350 to spray the two boxes, needless to say, I obviously didn't go that route. I found a local ArmorThane franchisee that had recently started his business, he sprayed the two boxes and tray for $70, only asking to spread the word for future business.
Here are closer pics
