5W-20 vs. 5W-30 with MDS?
Old Jul 22, 2008 | 09:03 PM
MikeHTally's Avatar
MikeHTally
Default RE: 5W-20 vs. 5W-30 with MDS?
5w-30 keeps the
Old Jul 22, 2008 | 09:05 PM
MikeHTally's Avatar
MikeHTally
MDS from engaging. No, 4.7s don't have
Old Jul 22, 2008 | 09:06 PM
MikeHTally's Avatar
MikeHTally
MDS. Only '06 and newer Hemis. Man, talk about censorship!
Old Jul 22, 2008 | 11:42 PM
Ben D.'s Avatar
Ben D.
5w20 is the only way to go for the hemi. the mds is activated by allowing oil into different passages in the engine adn by using a heavier weight oil you affect how the oil moves thru said passages in the engine.
Old Jul 23, 2008 | 12:09 AM
kicker417's Avatar
kicker417
i used 5-30 and made no difference at all
Old Sep 4, 2008 | 09:08 PM
GaryG's Avatar
GaryG
Got a '07 1500 5.7/hemi w/16k miles.
Been using 5w20 Mobile 1; but the last time I changed the oil, I drained it out before realizing I only had 5W30 Mobile 1 in the garage. Debated the consequences for a minute, and went ahead and put the 30 weight in.
Been driving for 5k miles now. MDS engages as usual, and no change in mileage. Bottom line: no change at all noted.
One note: I'm in Virginia and it has been a warm summer. Maybe the heat is thinning the thicker 5w30 enought to make it work when it might not otherwise. Maybe the fact that I'm using Mobile 1 (synthetic) made it less of an issue. Dunno.
Yea, I'll go back to 5w20 at the next oil change, but 5w30 for 5k miles didn't seem to affect things under the hood any. FWIW.
Old Sep 4, 2008 | 11:28 PM
eaglestorm's Avatar
eaglestorm
Originally Posted by dreman
My 4.7 has MDS?
No 4.7 is not a mds eng only 5.7
Old Sep 4, 2008 | 11:33 PM
eaglestorm's Avatar
eaglestorm
5w 30 can make the mds mess up use only 5w20 If you use 5w30 it Will set a code in the pcm for wrong oil It knows trust me I have seen it you can use just about any 5w20 even syn but dont use k mart brand (that type) if you use 5w30 and go in and complain about your mds system the will see the code and tell you to change your oil you may not feel any diff in the mds but if there problems the pcm knows
Old Sep 30, 2022 | 10:28 AM
TheodorePapalexis's Avatar
TheodorePapalexis
Default 5w-30
Originally Posted by Wapakfred
I've seen this mentioned several times here, and the caution was always to stay with the 5W20...so I do. It's my understanding that using the heavier oil will affect the MDS adversely.
I have a 2014 ram 1500 and on Page 689 of my manual it says that you can use 5W-30 in place of 5W-20 if 5W20 is unavailable. I recommend taking a look at the “maintaining you’re vehicle” part of you’re owners manual.
Old Sep 30, 2022 | 01:53 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Wow, 14 years later lol. Did you register just to post that one little late as all hell tidbit LMAO?
