additive
Old Jul 28, 2008 | 02:00 PM
maxxiss's Avatar
maxxiss
Default additive
going to change to syn rear end fluid what do you guys recommend and it does have an anti spin rear end do i need to ad an additve .
Old Jul 28, 2008 | 04:05 PM
HammerZ71's Avatar
HammerZ71
Default RE: additive
I've found on all my older trucks with a LSD (I have an Auburn Gear LSD in my current truck that specs conventional lube and the additive) that even if the synthetic stated you didn't need an additive that I got a little chatter around turns on occasion. After adding the additive it always went away, so I'd say to go ahead and put about 4 oz. of additive in anyway...
Old Jul 28, 2008 | 05:04 PM
toxdoc's Avatar
toxdoc
HammerZ71 is probably accurate however I switched to Royal Purple when I added the PML differential cover and although I purchased the Mopar additive I did not use it, and have not encountered any chatter. It may depend on which synthetic you choose?
Old Jul 28, 2008 | 07:53 PM
MikeHTally's Avatar
MikeHTally
Four quarts of Mobil 1 75w-140 (larger diff cover) and seven ounces of friction modifier. Easy project (easier than the tranny version).
