Fuel Inject Cleaner
Old Jul 29, 2008 | 09:08 PM
andrew64's Avatar
andrew64
Default Fuel Inject Cleaner
Just wanted to know what you all thought about fuel injection cleaners? Worth it or waste of money? and what brand do you recommend? I have a 2008 5.7L hemi 4x4.
Old Jul 29, 2008 | 09:19 PM
MikeHTally's Avatar
MikeHTally
Default RE: Fuel Inject Cleaner
Well, the forum is blocking intelligent responses again. I use Seafoam about once a year. Follow the directions. It seems to work well.
Old Jul 29, 2008 | 09:20 PM
MikeHTally's Avatar
MikeHTally
Let your truck, car, whatever, inhale 1/3 of a can through the brake booster line, 1/3 into the crankcase just before you drain it,
Old Jul 29, 2008 | 09:21 PM
MikeHTally's Avatar
MikeHTally
then treat a tank of gas with it. I forget the ratio, but it's on the can. It works well, but probably only needs to be done yearly.
Old Jul 29, 2008 | 09:33 PM
rtmtrrdr's Avatar
rtmtrrdr
SINCE I CAN'T POST WHAT I WANTED TO SAY!!!!
Old Jul 29, 2008 | 09:35 PM
rtmtrrdr's Avatar
rtmtrrdr
lucas oils fuel injector cleaner works the best( i think)
Old Jul 29, 2008 | 09:47 PM
Mancunian's Avatar
Mancunian
I remember reading that modern gas contains an effective detergent so injector cleaner is not required...
Old Jul 29, 2008 | 10:09 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Believe it or not...TC-W3 2 stroke oil works great when used 1 oz per 5 gallons of gas or 1:500 ratio. TC-W3 is ashless and burns completelyso it won't hurt your cats or o2's.
Old Jul 29, 2008 | 10:31 PM
mmstar23's Avatar
mmstar23
lucas fuel injector cleaner is suppose to be pretty good stuff. havent used it myself
Old Jul 29, 2008 | 10:42 PM
HammerZ71's Avatar
HammerZ71
I usually put a bottle of Lucas in about twice a year, which is basically about every 3000 miles on the truck...
