Reverse Lights
Old Aug 1, 2008 | 09:01 AM
mozingod's Avatar
mozingod
Default Reverse Lights
Odd, I swore I just posted this, but can't find it anywhere. Hope it's not a double post.
Anyway, both of my reverse lights are out, and pretty much at the same time. I tried replacing the bulbs and still no luck. Would it be the reverse switch on the transmission (it's a manual V6)? Any idea if it's a PITA to replace, or if it could be something else?
Thanks,
Darrell
Old Aug 1, 2008 | 01:27 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Reverse Lights
You could get a tester, pull the bulbs, put the truck in reverse and see if you get juice to the socket. If not, then yes I would say switch. No idea on difficulty of the replacement.
Old Aug 1, 2008 | 11:44 PM
mozingod's Avatar
mozingod
Did that... no juice. Turns out it was the fuse. Go figure. Haven't had one of those go bad in a vehicle in so long I completely forgot about them.
Thanks for the help!
