Airconditioner Blower obstruction?
Old Aug 7, 2008 | 08:32 PM
johnymauris's Avatar
johnymauris
Junior Member
Default Airconditioner Blower obstruction?
Is there an inlet air filter on the airconditioner blower that could be obstructing the blower air flow? The blower isn't blowing air nearly as strong as it was when it was new, it's like there is an obstruction of some kind, 2006 ram 1500. Any ideas on what the problem could be?
Old Aug 7, 2008 | 10:25 PM
josephland34's Avatar
josephland34
New Member
Default Yes!!! Just had mine fixed yesterday
Had to pull the heater box out to replace a door/flap that stuck the ac between recirculating and fresh ac. Mine as yours should be was under warranty, had it fixed when getting oil changed and seatbelt fixed on recall. Now I can't even put it on two without freezing, before I was still sweatin on full blast.
Old Aug 8, 2008 | 03:46 AM
devildg84's Avatar
devildg84
i also have a 06 ram and they had to replace the recycled/fresh air blend door bc of the same problem it was covered under warrenty when i had it done
Old Aug 8, 2008 | 09:27 AM
Bville_Okie's Avatar
Bville_Okie
Junior Member
Same issue here. There are two doors and one broke in a fashon that blocked the other from closing all the way. Basically i was getting a blend of ac air and outside air. The air speed from the vent as well as the temp were all screwed up. Its typical in the Rams from what i have read on this forum in the past two years.
Old Aug 8, 2008 | 12:27 PM
Parts/Service's Avatar
Parts/Service
The 2006's are know for needing a new recirculation door.
Old Aug 26, 2008 | 01:46 PM
rdpatt56's Avatar
rdpatt56
Is this a factory defect?
Old Sep 1, 2008 | 05:57 PM
devildg84's Avatar
devildg84
i think it should be i have heard alot of people having this problem
Old Sep 1, 2008 | 07:17 PM
eaglestorm's Avatar
eaglestorm
Default Recirculation Door
Dodge has a problem with the recirculation door they forgot to put a stop
so the motor twist the door apart you have to replace the recerc housing that comes with a new door and motor
Old Sep 2, 2008 | 05:44 PM
josephland34
New Member
Default Swirls in the paint
Okay now anybody's paint job just horrible?
