Another engine light on question....
Old Aug 9, 2008 | 08:46 PM
Mancunian's Avatar
Mancunian
Default Another engine light on question....
The error code is the usual one for a slight leak in the fuel vapor scavenging system. I changed out the gas cap and checked the manifold hoses but the light is still on. Where else should I check? Does the light need to be reset or should it go off on its own when its fixed?
Steve
Old Aug 9, 2008 | 09:23 PM
HammerZ71's Avatar
HammerZ71
You can try to reset it and see if it comes back. If it does pay close attention to the lines around the canister. Look for cracks around the ends, it's a common issue which can usually be fixed by just cutting the cracked end off and re-attaching it...
