Trans Fluid ?
Old Sep 2, 2008 | 10:49 PM
r91488's Avatar
r91488
Default Trans Fluid ?
Okay I am getting ready to service the Trans what is a good estimate of Fluid that I have to purchase, being that this is my only vehicle I would like to be prepared, what fluid is recomended I have an 04 Quad Hemi I do not know the trans I have, it is a Laramie as well, and it is a 2wd, so a good estimate would be appreciated, also I plan on servicing the Diff is there a quick way to know if I have a posi or not or should I put friction modifier in it anyways? Beside the Trans, Engine, and Diff is there anything else I should do? Not knowing what has been done in the past, I know I should have the brake fluid flushed I will have a mechanic do that I am not the best with brakes, thanks
Old Sep 3, 2008 | 09:16 PM
kiggy74's Avatar
kiggy74
I just did my trans on an 05 Hemi Quad 4x4. Needed about 8 qts of fluid. I bought Castrol ATF+4 and used the Mopar filters. I changed both filters at 50,000 even though the manual says the screw on filter only needs changed at 90,000.
You'll need a plastic chisel and plastic brillow pad to clean the old gasket off of the tranny pan. That part took the longest, including cleaning up the mess of tranny fluid I left in my driveway.
Old Sep 3, 2008 | 09:30 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
look on the tube of the rear axle, just inside the right side wheel. should have a label wrapped around there tell you if its an open diff or limited slip.
