tires 3in lift
Old Sep 3, 2008 | 09:43 PM
ausburn15's Avatar
ausburn15
Default tires 3in lift
i have an 05 2wd and just put the rough country 3in lift on it with 1.5in blocks in the back what size tire can i run i really want to runa 35 and not rub alot
Old Sep 3, 2008 | 09:47 PM
HammerZ71's Avatar
HammerZ71
You'll clear 'em, might rub on extreme turns or really bad bounces, but for the most part you'll be ok. If you have the stock rims you might want to opt for a 35" by no more than 11.5", but if you've got aftermarkets with a little more backspacing, you could run 35x12.5's pretty well...
Old Sep 4, 2008 | 12:14 AM
jumper82's Avatar
jumper82
I'm putting on a 2" kit to level it out, what's the biggest I can run on stock rims. I have 245/70R17 now. I thought they were supposed to be 265s but apparently these aren't.
Thanks
Old Sep 4, 2008 | 07:36 AM
HammerZ71's Avatar
HammerZ71
Thanks
need to know what year and if it's a 4x4 or 4x2, it makes a difference...
Old Sep 4, 2008 | 10:53 PM
jumper82's Avatar
jumper82
It's a 4wd.
Old Sep 4, 2008 | 10:59 PM
jumper82's Avatar
jumper82
I was looking at the BFG All-Terrain T/A KO or the Mud-Terrain KM. Something good in the mud, but with longer life and more aggressive looking than the stock ones on right now.
Thanks
