abs speed sensor
Old Sep 10, 2008 | 05:17 AM
blr's Avatar
blr
Default abs speed sensor
I just changed out a front wheel hub on a 2004 Dodge Ram Quad Cab 4x4, the speed sensor pickup coil on the new hub I think is a different resistance than the original as it kicks out my abs, the plug in was also different, I heard that Dodge changed the connecting plug in 2005, did they also change the resistance of the pickup coil?? If they did then this would explain why my abs is now kicking out. Unfortunately I cannot use the original speed sensor in the new hub as the coil appears to be damaged.
