1500 Ram Wheel Specs?
What are the specs for the both the 17" and 20" wheels for the 1500's? Lug size, spacing, dia., backspacing & etc.?
Been having trouble finding aftermarket wheels to fit. I figured if I had the actual specs I might find some other options.
Thanks!
Thanks!
Your specs for your truck should be 5x5.5 that is the spacing. That should be all u need to type in to look at most sites on the internet. I found them really easy putting that in. hope that helps
Yup anything that's 5 on 5.5 and at least 17" in diameter should fit. Now if you are thinking of oversize tires, that's where the backspacing, offset, etc. would come into play...
Just stock 265/70 R17 tires.
