Bent Rear Leaf Springs?!? 03 1500
Old Sep 13, 2008 | 10:40 PM
jeremyrowell's Avatar
jeremyrowell
Default Bent Rear Leaf Springs?!? 03 1500
The rear of my 03 1500 seems to be setting lower than it has in the past. I was looking under it today and noticed the rear leafs look like they are bent. The thick overload(?) spring on the bottom is actually bowing a little in the wrong direction. The rest of the leafs are straight where the ubolts clamp on then bow a bit DOWN before arching back up. I have never really looked that close at them before... so it could be normal. Can amyone confirm this?
I DO tow my jeep sometimes and *may* have overloaded it once...
Old Sep 14, 2008 | 05:50 PM
jeremyrowell
Default Anyone????
Can any take a look at their rear springs and tell me if they are a regular arch or are they a little flat near the ubolts?
Is the large short bottom sping arched or flat our arched towards the ground?
Old Sep 14, 2008 | 08:10 PM
kx250frider617's Avatar
kx250frider617
the over load spring should be like that. Its probably fine. I have loaded a whole pallet of marble in my truck. Around 2,000 lbs in the bed for like 4 miles. I have airbag helper springs and those were totally collapsed with 80psi. My springs arn't bent. Plus I haven't really heard of any instances were a leaf bends.
