claybar question
Old Sep 19, 2008 | 03:52 PM
sk425k's Avatar
sk425k
Default claybar question
I posted earlier in the week in the detailing section no responses.. when useing it should you just do certian areas that arent smooth opr sould you do the entire painted surface? thank stephen
Old Sep 19, 2008 | 04:20 PM
irelandshemi's Avatar
irelandshemi
Old Sep 19, 2008 | 04:24 PM
MikeFarm's Avatar
MikeFarm
I've normally always done the entire area, I find that the clay bar leaves it smoother even when you think it is smooth.
Old Sep 19, 2008 | 05:01 PM
Johnboy7701's Avatar
Johnboy7701
yeap you can do the entire painted surface and make sure you spray plenty of detailing spray you dont wanna rub dry clay on the surface... once your done claybarring hit it up with some good wax...
Old Sep 19, 2008 | 09:25 PM
hilljacknm's Avatar
hilljacknm
Clay bar is great. FYI, you can use plain water instead of detailing spray. Just fill up an empty spray bottle with tap water.
Old Sep 19, 2008 | 10:31 PM
RaiderJay6's Avatar
RaiderJay6
Dont drop the bar on the ground either! LOL
