need some help
Old Sep 29, 2008 | 02:15 PM
03dodge's Avatar
03dodge
Default need some help
Hey just wondering if any of you guys have had this problem. About six weeks ago my truck a 03 dodge 1500 2wd 4.7 auto started dying at complete stops had the fuel pressure checked and it was at 47 pounds dealer says it should be at 50 pounds plus or minus 2 pounds. So I changed the pump to a Airtex and about two weeks go by and my truck starts surging right after being started with engine cold or hot, but the truck starts and runs fine. It idles at about 500rpms but when it starts surging it jumps from 500 to a little over a 1000, but it only does this with the truck in park or neutral for a short time. I had it hooked up to a scanner to check things out and every thing was fine, checked the pressure and it was a little low. So I changed the pump again to a Bosch three days ago and as soon as I started it up it started all over again. I changed the pump again to a Delphi Saturday no problems yet. Have been told by dealer it could have been something in the pumps. Just wondering if you guys have any thoughts on this?
Old Sep 29, 2008 | 08:32 PM
rtmtrrdr's Avatar
rtmtrrdr
yeah,i've had that happen to me in my old ford ranger.i replaced the pump like 4 times,and it kept doing that same thing.it turned out to be the fuel pump relay in the main junction box under the hood.i replaced that and had no problems with it again
Old Sep 29, 2008 | 09:52 PM
Parts/Service's Avatar
Parts/Service
I know some here will disagree with me, but I have probally seen more Dodge fuel pumps changed out than most everyone here. I have not seen any good aftermarket pumps built for a Dodge. The aftermarket ones just don't last.
Old Oct 4, 2008 | 09:33 PM
03dodge's Avatar
03dodge
Thanks for the input guys. I talked to two different mechanics and they both said it sounded to them like the IAC Valve (Idle Air Control Valve) needed to be cleaned or replaced. So I cleaned it Thursday evening and found that it was pretty nasty there was a big chunk of carbon build up inside the throttle body. As of today it has idled perfect.
