Wierd
Old Oct 2, 2008 | 08:00 PM
03 ram larame's Avatar
03 ram larame
Angry Wierd
I noticed my truck was idling quieter it was at 600 rpms power didn't seem right and now the cruise doesn't work turn it on then press set and it shuts off,it got p585 and p2161 codes,weird thing is I have never seen those codes anywhere I have looked.
03 ram larame
oopps sorry 03 dodge ram 1500 quad laramie hemi.
Old Oct 2, 2008 | 10:02 PM
Pyro's Avatar
Pyro
I Beat Tetris
P0585 Cruise Control Multi-Function Input "A"/"B" Correlation
P2161 Vehicle Speed Sens B Interm/Erratic
Taken from http://www.superchips.com/force_down...ion-pdf-69.pdf
Old Oct 3, 2008 | 12:14 PM
truckin151's Avatar
truckin151
Had the p2161 pop up a few times on mine. It happened on mine after I had new tires put on. The fix (or at least what cleared it for me) was to 1. reset the tire size on my programer (the tire size went up about half an inch) and 2. I got my brakes done as they needed to be replaced. The combo between the 2 got rid of the code and I haven't seen it since. I think it had more to do with getting the brakes done than anything though... Not sure if that helps any but thats what did it for me
Old Oct 3, 2008 | 05:39 PM
03 ram larame
No it helps cause I did start hearing the brake tabs on the shoes making noise front I think,now what about the 585 code is that an electronic problem with the cruise control?
