fog lights
Old Oct 5, 2008 | 12:43 PM
sunburst08's Avatar
sunburst08
Default fog lights
anyone know how to adjust the foglights? also how to do you tighten them, i have a passenger side foglight loose? thanks
Old Oct 5, 2008 | 01:24 PM
RaiderJay6's Avatar
RaiderJay6
3 bolts hold them in and they have a screw on the top to adjust them up and down.
Old Oct 5, 2008 | 08:29 PM
talon6's Avatar
talon6
sucks,i had a rock hit one of mine the other day and bust the lens. now i need a new one. can i buy one at a time?
Old Oct 5, 2008 | 11:11 PM
RaiderJay6's Avatar
RaiderJay6
Ebay sometimes has one.
Old Oct 5, 2008 | 11:55 PM
Tonyo88's Avatar
Tonyo88
You should be able to buy one at a time at most auto parts stores. I had the same problem, took a rock and busted. Replaced it, and a week later, it got hit with another rock. Didn't break the second time, just cracked real good.
Old Oct 11, 2008 | 11:56 PM
sunburst08's Avatar
sunburst08
Default foglight
thanks all, turned out to be a busted bracket, it was causing the light to bounce all over the place. by the way, any one know what size the top adjusting screw is for the foglights? thanks
Old Oct 12, 2008 | 10:22 AM
hilljacknm's Avatar
hilljacknm
Believe it is a # 20 Torx .
Old Oct 12, 2008 | 01:03 PM
sunburst08's Avatar
sunburst08
Default foglight
cool thanks. will give it a try.
Old Oct 15, 2008 | 11:26 PM
Erich's Avatar
Erich
My bracket was cracked had the dealer check it and order a new one under warranty. Haven't been back to dealer and now the fog light completely snapped off and was hanging by the wire harness, guess I'm lucky I didn't lose it. Seems like a bad design to have it crack/break so easily. I had the fog light on my intrepid hit with road derbies and was able to pop it right back in with no broken parts.
