Changing Front Stud?
I was going to rotate the tires and at some point, one of the dealers or tire shops screwed up one of the studs. The lug was jammed on there, not I need to replace the stud.
Is there enough room to tap out the stud, or do I need to remove anything behind the rotor?
On my other car, I can rotate the wheel and there is a gap where you can push the stud all the way through.
Thanks.
Thanks.
