Fluid change = no move?
Old Oct 19, 2008 | 07:21 PM
ScottJ175's Avatar
ScottJ175
Default Fluid change = no move?
Did a fluid and filter change. Seemed perfectly straightforward.
But after putting in fluid until it was showing on the dipstick she won't move in any gear.
I show full when idling in neutral.
What could I have done wrong?
Old Oct 20, 2008 | 01:50 AM
ScottJ175's Avatar
ScottJ175
It was a failure to read and follow directions.
I didn't seat the seal in the pump first so the filter came loose when I put the pan up.
Thankfully I was able to salvage a good bit of the $8 a quart Mobil 1 ATF and had enough extra on hand to make up for what I lost.
Old Oct 20, 2008 | 02:43 AM
abarmby's Avatar
abarmby
You mean the seal that you MUST fit first before pushing in the large flat pancake style filter afterwards don't you?
Al.
Old Oct 20, 2008 | 10:40 AM
ScottJ175's Avatar
ScottJ175
Yes. Read the directions and processed them exactly backwards.
I was thinking "must be seated on filter".
Turned 40 back on the 6th. This is not a good sign.
