Got screwed by dealer on fog light install, suggestions.....
Old Oct 24, 2008 | 09:56 PM
tlarimer's Avatar
tlarimer
Angry Got screwed by dealer on fog light install, suggestions.....
I had fog lights installed on my 08 1500 Mega Cab SXT. I didn't know that there was 2 different kits and assumed the dealer would have put in the correct kit. So I get the truck back and there is a hole in the dash where they mounted the new foglight switch. Assumed that was normal. Well today I discovered that my truck is pre-wired for foglights. Do I have a right to have the dealer uninstall the incorrect foglight kit, install the correct foglight kit and replace the part on the dash that they drilled through? I mean this problem now comes down to there negligence and stupidity, as well as my not researching a little before I trusted the dealer to do the install. Thanks for any suggestions.
Tim
Old Oct 25, 2008 | 12:25 AM
RaiderJay6's Avatar
RaiderJay6
Sure you do! They are f-ed up and messed it up!
Old Oct 25, 2008 | 01:06 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Yup...have them re-do it for free. Regardless of what BS they'll try to tell you they are the ones that pulled up the wrong part number and installed the wrong kit....unless you bought the kit elsewhere.
Old Oct 25, 2008 | 11:47 AM
damien1023's Avatar
damien1023
im just curious... how much did they charge you for install?
Old Oct 25, 2008 | 03:53 PM
WhiteBerry's Avatar
WhiteBerry
shoulda got the kit on ebay, i did it myself in under an hour, in the street
but yea, they are idiots for doing that to you, anytime they need to drill a hole in your dash they should let you know first... incompitance runs rampant in the service industry!!!
Old Oct 25, 2008 | 04:01 PM
eaglestorm's Avatar
eaglestorm
It's not the wrong kit . The kit come with a wiring harness for trucks that dont come pre wired. most do but the kit dosen't come with a new headlamp switch. That you need if you not installing the extra wiring harness. It also dosen't come with the harness that connects the fog lamps to the factory wiring. So you need the kit then a new head lamp switch. and the jumper harness. then you have to use a star scan to enable fog lamps in the tipm. With the extra parts the sys cost more but labor should be a little less because you dont have to install the extra harness.If your dealer is a stand up place they will correct the problem .
Old Oct 25, 2008 | 11:17 PM
tlarimer's Avatar
tlarimer
I bought the fog light kit through the dealer, it was done at the same time I bought the truck, the dealer told me the had to order the kit and would call me when it was in.
I don't remember what the install price was, somewhere around $150.
It is the wrong kit if my truck came prewired for fog lights, hence the reason why dodge makes two seperate kits, with two different P/N's.
Old Oct 25, 2008 | 11:37 PM
SeVeReDiStOrTiOn
Originally Posted by eaglestorm
It's not the wrong kit . The kit come with a wiring harness for trucks that dont come pre wired. most do but the kit dosen't come with a new headlamp switch. That you need if you not installing the extra wiring harness. It also dosen't come with the harness that connects the fog lamps to the factory wiring. So you need the kit then a new head lamp switch. and the jumper harness. then you have to use a star sacn to enable fog lamps in the tipm. With the extra parts the sys cost more but labor should be a little less because you dont have to install the extra harness.If your dealer is a stand up place they will correct the problem .
His truck is pre-wired, so yes it is the wrong kit...like you said yourself it doesn't have the Y harness or light switch.
Old Oct 26, 2008 | 06:37 AM
JCW355's Avatar
JCW355
My truck wasn't pre-wired, I put in the kit you are talking about.
Old Oct 26, 2008 | 11:23 AM
bolang's Avatar
bolang
raise 10 kinds of hell.they need to fix it.drilling holes in your dash hell i'll come and woop their ***
