O6 Leveling Kits, Bad Shake
Old Nov 7, 2008 | 07:51 AM
SA9553's Avatar
SA9553
Default O6 Leveling Kits, Bad Shake
Hey Guys...I Have and 06 1500 quad...Just had a 2" leveling kit installed on it....Looks great but I have a horrible shake now...Starts at about 30mph and gets worst from.. Now I know your supposed to get it alined after you have it installed, I havent. Will that fix the problem or should I have something else done too.... Thanks
Old Nov 7, 2008 | 10:41 AM
TheBaker's Avatar
TheBaker
Get the alignment.
Old Nov 7, 2008 | 11:22 AM
bigmike05ram's Avatar
bigmike05ram
Talking
oh yea alignment
Old Nov 7, 2008 | 11:39 AM
HammerZ71's Avatar
HammerZ71
Do the alignment, but also check the coil spacer install, make sure they are seated on the bushings firmly!!!
Old Nov 7, 2008 | 11:44 AM
SA9553's Avatar
SA9553
Thanks Guys...Just heard from the Garage...Had a bad tie-rod end also...Kinda firgured that might be it as it shimmed before I had the level kit done...Just worst after I had it done.
Old Nov 7, 2008 | 08:38 PM
morepower29's Avatar
morepower29
when the spacers are put on above the struts it drastically changes angles. this causes the camber to come out of wack. So when you have it aligned have them adjust that too.
