how to remove the glove box?
Old Nov 15, 2008 | 02:58 PM
kcdeife's Avatar
kcdeife
Default how to remove the glove box?
I was looking at the glove box and I do not know where to start and do want to cause any damage. So how do you remove the glove box on a 2006 dodge ram 1500.
Thanks
Old Nov 15, 2008 | 03:51 PM
bwhite757's Avatar
bwhite757
It's easy, open it up, and squeeze the left and right of the compartment toward eachother, then just continue to pull out.... hmmm.. hope that makes sense....
The glove compartment is held in place by two tabs at the bottom that let it pivot open and closed, and then two "bumpers" on each side of the compartment that keep the glove box from continuing to pivot open and fall onto the floor.... You squeeze it inward to let the "bumper catches" pass their stops...
Old Nov 15, 2008 | 03:53 PM
Bensredram's Avatar
Bensredram
That's how I did it.
Old Nov 21, 2008 | 09:54 PM
DodgeAdvisor's Avatar
DodgeAdvisor
1.Open the glove box 2.Release the two glove box stops and lower the glove box downward past the stops.3.Disengage the glove box hinges from the instrument panel and remove the glove box.
