Warranty and ball joint replacement.
Old Nov 19, 2008 | 09:40 AM
pinoydodge's Avatar
pinoydodge
Default Warranty and ball joint replacement.
My 05 1500 2wd is leaking a small amount of coolant after sitting overnight. The leak seems to come out from the upper part of the front engine. My truck has 64K miles on it and I was wondering if this falls under the 7/70K powertrain warranty?
Problem # 2, upper ball joint driver side is going bad. How hard is this to replace DIY? I know will need alignment after replacing.
Any input is appreciated.!!!
Old Nov 19, 2008 | 11:28 AM
dirtydog's Avatar
dirtydog
Moderate User
Waterpump may be going bad. If it starts to leak out the weep hole, than it's going bad.
Upper balljoint is going to be a PIA. It hass all the pressure from the springs. I would say just ket them do it while the fix your coolant issue Prob be like $2-250 with alignment since alignments are outrageously expensive compared to a few years ago. They get like $75 for just the front axle(all you need since you have a solid rear axle
