hella 500s
Old Nov 25, 2008 | 09:38 PM
nickahern1's Avatar
nickahern1
Default hella 500s
just got a pair of hella 500s for behind the grill. going to install them sometime tommorow or friday. im not digging the suggested wiring diagram in respects to tapping into the hibeam 12v source. I want them to be manual and not come only when hibeams are on. I was planning on tapping the 12v source from the cig lighter to the switch. That should do the trick right? The cig lighter only is powered when the ignition is in the on postion correct? i cant wait to put them in. I got them for $55 from walmart tonite if anyones looking for a nice set.
Old Nov 25, 2008 | 11:08 PM
damien1023's Avatar
damien1023
lol, i have been looking at these for the past week too. i may pick up a set and put them in thursday for friday as well
Old Nov 25, 2008 | 11:09 PM
nh5's Avatar
nh5
The 12 volt cig lighter will not be a good idea for them as they most likely draw more then it supports. Maybe tie into the regular headlight wiring and then add a switch to turn them on and off seperate from headlights.
Old Nov 25, 2008 | 11:47 PM
nickahern1's Avatar
nickahern1
the cig lighter 12v supply is for the switch. its also connected to a relay which is connected to + battery. so it will not draw more power.
heres how it will be wired
(ill use one light to sum it up because they are jumped together anyways)
blue wire on light grounded
black wire to relay
red wire from relay to + battery
another blue wire from relay to ground
yellow from relay to switch
green from switch to 12v power supply ( cig lighter)
another blue from switch to ground
i got my snaswer my just thinking about it anyways.
yellow wire to switch
Old Nov 26, 2008 | 01:01 AM
kornbred01's Avatar
kornbred01
how exactly are yall mounting these light to the back of the grill? is it the stock grill?
Old Nov 26, 2008 | 03:28 AM
yugowego's Avatar
yugowego
I got a pilot wireless hookup on ebay for 9.00, hooked the box to the battery, ran the wires from the box to my KC daylighters, bam, we have light. was real easy!
Old Nov 26, 2008 | 06:24 AM
TRXHemi's Avatar
TRXHemi
Most are mounted on the bar that runs behind the grill. Very easy to do....
Old Nov 26, 2008 | 06:32 AM
TRXHemi's Avatar
TRXHemi
Here is a pic - mine are not the Hella 500s but are a little smaller.
Old Nov 26, 2008 | 06:14 PM
nickahern1's Avatar
nickahern1
just installed them and damn they are bright. they look soo nice when they are on but really cant drive around with them, just when i need them. nice mod for cheap money and an easy install.
Old Nov 26, 2008 | 06:27 PM
damien1023's Avatar
damien1023
post up some pics!
