1500 2006 windshield pump power
Old Dec 2, 2008 | 02:08 PM
jamesim's Avatar
jamesim
Default 1500 2006 windshield pump power
hello
2006 ram 4x4 1500
i am having trouble looking for the fuse for the washer.
the pump works, i tested it.
it seems its not getting power. i checked all the fuses under the hood
and they all work.
does it have a separate fuse?
thanks
james
Old Dec 2, 2008 | 02:19 PM
RubberFrog's Avatar
RubberFrog
Look in your owners manual.
Old Dec 3, 2008 | 10:21 AM
jamesim's Avatar
jamesim
i checked the manual
there is no fuse for the windshield pump or
anything with windisheld
maybe is abbreviated or under a differnt name
but i checked the fuses with a tester..ones that check with a light.
all fuses seems ok.
i am confused.
james
Old Dec 14, 2008 | 06:22 AM
marragtop's Avatar
marragtop
I'm having the same problem with my 05 Dakota. Is there any fuse/relay/fusible link for the washer pump, or does it use the same one as the wipers? thanks
Old Feb 2, 2009 | 01:53 PM
rbenkemeadow's Avatar
rbenkemeadow
I have a 06 durango limited with the 5.7 and have the same problem. inside the engine bay are 2 fuses for hi/lo and on/off. i pulled one at a time and nothing works without both in. i also unplugged the pump and tested the volts and nothing showed on the volt meter.
