Plugs and wires on 02 1500 4.7
Old Dec 6, 2008 | 08:44 PM
bulletperformance's Avatar
bulletperformance
Default Plugs and wires on 02 1500 4.7
I am thinking about running an 11 or 12mm plug wire with E3 plugs. i have the banks exhaust and the k&n intake Also does anyone have the tbody spacer what are the advantages and dis advantages
Old Dec 8, 2008 | 12:36 PM
HemiLonestar's Avatar
HemiLonestar
Correct me if I'm wrong, but I don't think you need wires, since the 4.7 has COIL ON PLUG ignition?
Old Dec 8, 2008 | 02:08 PM
KrazyBrian's Avatar
KrazyBrian
I have a t-body spacer for sale ($50) that should work for you....it won't work on my 06
I also have a venom 400 performance control module if interested
Old Dec 11, 2008 | 04:57 PM
bulletperformance
i honestly have not even looked at the plugs on my truck.. ill look for the cop and brian how much for the control mod
Old Dec 11, 2008 | 08:17 PM
OlDirtyJohn's Avatar
OlDirtyJohn
throttle bodies "spacer/adapters" are a waste of money. itll end up being the most expensive paper weight youve ever owned. Sorry KrazyBrian, but i just dont want someone to waste their money on **** that doesnt work.
Old Dec 12, 2008 | 01:41 AM
AIR RAM's Avatar
AIR RAM
Originally Posted by OlDirtyJohn
throttle bodies are a waste of money. itll end up being the most expensive paper weight youve ever owned. Sorry KrazyBrian, but i just dont want someone to waste their money on **** that doesnt work.
I think you ment to say THROTTLE BODY ADAPTERS... But a 70MM throttle body is a GOOD mod! I currently have a FAST MAN 70MM and Im about to go to a new 72MM throttle body.
SPEED SAFE, AIR RAM
Old Dec 12, 2008 | 01:52 AM
OlDirtyJohn
SPEED SAFE, AIR RAM
you are correct sir. as i was... throttle body SPACERS/ADAPTERS are a waste of money. high quality aftermarket throttle bodies such as the ones you can purchase through Air Ram or Dan the Fast Man are a great investment, and work well.
good catch AIR RAM, and I hope you just got my order for the plugs and wires
Old Dec 12, 2008 | 11:45 AM
nickahern1's Avatar
nickahern1
i may be wrong on the 02 4.7l but i know my 06 has coil packs on plug so there is no need for plug wires. just grab some new plugs and your good to go.
Old Dec 12, 2008 | 12:40 PM
KrazyBrian's Avatar
KrazyBrian
Doesn't bother me I just want to get rid of the paperweight i can't use anyway...and to bullet, the venom box won't work for you, won't work with 02's, 01's and down only
