'07 2500 4x4 question
Old Dec 9, 2008 | 04:37 AM
redrum25's Avatar
redrum25
Default '07 2500 4x4 question
My owners manual says there's a grease fitting in the front driveshaft that needs to be serviced at each oil change (2500 & 3500 models only). Lubed the tie rod ends tonight - everything else on the front end lacks zerks, naturally - so I checked the spot indicated in the manual for the front shaft, but I can't find any fitting there. It's supposed to be right on the yoke just forward of the transfer case. Is this an error in the manual, a later design change or is my truck missing something? TIA
Old Dec 9, 2008 | 12:51 PM
Bass Hunter's Avatar
Bass Hunter
there is a write up in the cummins section in the diy threads at the top that explains hoe to do this pictures are great. You need a needle adapter for the end of your grease gun it doesn't have a zerk fitting.
Old Dec 9, 2008 | 04:31 PM
redrum25's Avatar
redrum25
Thanks a bunch for the help. It still looks like a PIA, but I'll try it.
Here's the link in case anyone else is looking for this: https://dodgeforum.com/forum/dodge-c...e-fitting.html
