fast idle when cold
Old Dec 20, 2008 | 11:48 AM
04 HEMI 04's Avatar
04 HEMI 04
my hemi idles around 1500 to 1700 rpm during very cold days. IT never went over 2000 rpm.
Old Dec 20, 2008 | 11:34 PM
V_Scapes's Avatar
V_Scapes
so while on the subject, how long does everyone let their truck warm up until driving?
Old Dec 21, 2008 | 12:28 AM
04 HEMI 04's Avatar
04 HEMI 04
i usally warm up my truck for 2 to10 min to clear off the ice
Old Dec 21, 2008 | 09:35 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Just until the rpms drop to around 800 or so..
Old Dec 21, 2008 | 07:01 PM
mark6martin's Avatar
mark6martin
I normally wait till about 800 or 900 rpm which is about 1 to 2 minutes. Hard to wait when your in a hurry but then i take it easy. No ice here in Florida normally.
Old Dec 21, 2008 | 07:23 PM
04QC4X4's Avatar
04QC4X4
My 08 Hemi is the same way. It bothered me at first, but I'm used to it.
Old Jun 7, 2012 | 11:30 PM
bfloan87's Avatar
bfloan87
Originally Posted by mark6martin
I have an 08 mega cab with a 5.7 hemi. My problem is when I start it cold it revs up to 1500 rpm and takes about a minute and a half to idle down after that you can shut the truck off and restart it and it will do the same thing until warmed up. You can also shift it while still at the higher rpms (which i dont like to do) and go back to neutral or park and the rpms are low, but if you turn the engine off and restart the same problem until the engine is warm. I took it to the dealer because it is still under factory warranty and they said there were no computer or sensor problems and blame it on ethanol and varnish build up on the throttle plates. They recommend cleaning the fuel rails, throttle plates and air intake system for $230. I have cleaned the mass air flow sensor and throttle plate my self but that did not help. Does anyone have any ideas.
i baugt a DSP and shut that high idle off so when it starts it will rev and drop to idle speed in about 5 to 10 sec rather than 1min
