superchips
Old Dec 19, 2008 | 10:19 PM
irelandshemi's Avatar
irelandshemi
Default superchips
i saw this on craigslist but it says 04 and up i have an 03 and on the website it says 03-08 will this one work on mine and can it remove my governor ect http://detroit.craigslist.org/pts/963852689.html
Old Dec 19, 2008 | 11:47 PM
Ramdamit98's Avatar
Ramdamit98
http://www.superchips.com/products.p...Grand+Cherokee
The 3815 is upgradeable over the internet to include most gas Dodge trucks from '98-'08.
Old Dec 20, 2008 | 12:14 AM
irelandshemi
so then with the upgrade will it work on my 03 cuase on the bottom of that page it says what it does for rams but it start at 04
Old Dec 20, 2008 | 02:05 AM
AIR RAM's Avatar
AIR RAM
Yours is on there... actually yours was on the 3715 Programer that was balled up and put into the 3815... so without a doubt yours is supported.
SPEED SAFE, AIR RAM
817 800 7760
Old Dec 20, 2008 | 02:44 AM
irelandshemi
just makin sure dont want to drop 200plus and not have it do what i want, remove limiter shift points whatnot
Old Dec 20, 2008 | 04:33 AM
ram-fjallasport's Avatar
ram-fjallasport
I use this one on my 5.9L 2002 and can not change shift point.
I was able to change WOT shiftpoins when I used the milage XS program.
But after upgrading the unit that part was gone!
just my experience!
I am not sure if the unit disabled this on the 5,9L only, you better check it out!
Old Dec 20, 2008 | 06:48 AM
HammerZ71's Avatar
HammerZ71
WOT shift points are there on the '03 Hemi tunes. Non-WOT shift points are optimized and even though not user definable, are a big improvement over stock.
Rev & Speed limiter features are there. Go ahead and spend the $250, but make damn sure if the unit is used, the owner has returned his truck to stock, unlocking his VIN # in the tuner or it'll be a $250 paperweight to you...
Old Dec 20, 2008 | 09:50 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Agreed. Make sure it is unlocked before you give him the cash because if it is locked it costs a good amount to get Superchips to unlock it. Plug it into you truck and check it before you drive off (assuming you are meeting the seller in person).
Old Dec 20, 2008 | 12:51 PM
irelandshemi
yeah im planning on meeting him in person, when i plug it in will it give me an error or something to let me know its still vin locked?
Old Dec 20, 2008 | 01:35 PM
Off_Road_Teacher
When you plug it in the second screen should tell you if it is programmed already on another truck or set back to stock. You want it to say that it is set back to stock or something to that effect. If it says programmed then it is locked and won't work on your truck.
