Need help site to replace headlamp assy on '07 1500!
Old Dec 26, 2008 | 08:21 PM
haynebayne's Avatar
haynebayne
Default Need help site to replace headlamp assy on '07 1500!
I am not a body man! Thanks for any help that may pop up on this awesome forum. I love my Dodge truck!
Old Dec 26, 2008 | 08:58 PM
dirtydog's Avatar
dirtydog
Moderate User
What exactly is your question? Are you looking to remove the headlight? It's not hard, just a few screws.
Old Dec 27, 2008 | 05:58 AM
haynebayne's Avatar
haynebayne
Yes I was just hoping there wasn't some special trick involved before I start taking it apart. I need to buy a bumper too. Any idea on the best place to purchase one?
Old Dec 27, 2008 | 06:56 AM
SeMiGoD's Avatar
SeMiGoD
http://www.partsformydodge.com/oem_p...FSEfDQodhDNJ9g
Old Dec 27, 2008 | 07:41 PM
haynebayne's Avatar
haynebayne
awesome thanks!
Old Dec 27, 2008 | 08:38 PM
Parts/Service's Avatar
Parts/Service
1. Disconnect and isolate the battery negative cable.
2. Remove the oval-shaped rubber access hole plug from the forward upper outboard surface of the front fender wheel liner (4).
3. Reach through the wheel liner access hole to remove the nut (5) that secures the stud on the lower outboard corner of the front lamp unit (3) housing to the fender headlamp mounting panel.
4. With the hood panel opened, remove the two screws (2) that secure the inboard side of the lamp housing to the mounting panel.
5. Grasp the lamp firmly and pull straight forward to disengage the ball stud on the upper outboard corner of the lamp from the plastic grommet (1) in the mounting panel.
6. Pull the lamp away from the fender far enough to access and disconnect the three wire harness connections (4) from the headlamp bulb (2), the park/turn signal bulb socket (3) and the side marker bulb socket (5) on the back of the lamp housing.
7. Remove the front lamp unit (1) from the fender.
Attached Thumbnails Need help site to replace headlamp assy on '07 1500!-hl.jpg
Old Dec 28, 2008 | 09:01 PM
haynebayne's Avatar
haynebayne
No hurry but if you have one of those (views) for the bumper i would be really happy and very thankfull.
