hellas
Old Jan 2, 2009 | 04:37 PM
02Steve1990's Avatar
02Steve1990
Default hellas
Alright, I have checked many store websites and could not find where to buy the hella 500's, I don't want to order off a website because I would rather just go out and buy them. Does anyone know where to get these, also, is there a way to make them optional to turn on when your headlights and fog lights are already on? (Can you have them off when your headlights and fog lights are on?)
Thanks for the help in advance
Old Jan 2, 2009 | 05:04 PM
seawind3000's Avatar
seawind3000
Most auto shops should have Hellas. You can wire them in with a relay to your hi beam with the relay switch wire run from the hi beam ( or your fog lights or your low beam) through a switch so when the switch is on, the hellas will operate with your hi beam, flick the hi beam and the hellas go off, you don't need to fumble for switches when a car comes around the corner.
I have DRLs and HIDs so my hi beam is very wimpy, just a 50 watt halogen that is off set so it is very dull. I have my low beam, fog lights and my Hellas relayed to the hi beam switch through a switch on the dash so the DRLs won't run all the HIDs but with the switch on, hi beam runs them all, 6 HIDs
Old Jan 2, 2009 | 05:53 PM
MikeFarm's Avatar
MikeFarm
Walmart also carrys the Hella 500 & 500FF kits
Old Jan 2, 2009 | 07:15 PM
dirtydog's Avatar
dirtydog
Moderate User
I did a write up on this. Check it out https://dodgeforum.com/forum/off-roa...oad-guide.html
Old Jan 2, 2009 | 08:02 PM
nim81's Avatar
nim81
they used to sell them at cabella's . if there is one near you. got some from there for my old nissan hardbody.
grabbed the ff's at walmart for cheaper.
