Headlight disassembly??
Old Jan 3, 2009 | 12:56 PM
mike_b's Avatar
mike_b
Default Headlight disassembly??
Anyone taken a 3rd Gen Ram headlight appart. Need to remove the 2 adjusters bolts and clean the corrosion from the threads. Adjusters are attached to the back with 2 screws. Met with resistance when I took the screws out and tried to slide the adjuster out of the assembly. All tips greatly appreciated.
Mike B
Old Jan 3, 2009 | 12:59 PM
dirtydog's Avatar
dirtydog
Moderate User
For the corrosion spray some PB blaster and let it sit for a while. Then spread some Anti-sieze on them. You'll never have that problem again. Great stuff.
As for taking out the headlamp, try the search function because there was a specific how to that someone posted up just last week
