PA Lift, Happy?
Old Jan 5, 2009 | 07:55 PM
JamesVT's Avatar
JamesVT
Default PA Lift, Happy?
Hey guys, I've been seriously contemplating the PA 3" body lift with the Mopar wheel liners over the gap gaurds. My question is: It's often fairly hard to tell in the pics that the truck is even really lifted. For those of you who have put JUST this kit on their truck, running the stock 20" Rims with the 33" tires, could you tell a big difference? Does the truck really sit that much higher? Ride wise, did you sacrafice much? and also, looks wise, does it look that much better?
Old Jan 5, 2009 | 08:09 PM
dodge it then ram it's Avatar
I liked it a lot better. When I first put it on, it seemed higher than hell. Your tires will look small. It doesnt seem like much, but it was. Ride will stay the same. No change in suspension. If you want to get a feel for how it will look, measure the space from the top of your tire to the top of the wheel well. Then put a jack on the frame of your truck and jack it up until you get 3 inches higher than the measurement you took. For the front, put the jack under the front door. For the rear, put the jack right underneath your gas cover on the frame. Cheap trick but at least you can get a feel for what it would look like.
