08 Quad Cab Blinker Craziness.... Help!
Old Jan 14, 2009 | 01:35 PM
MeAndMyHemi's Avatar
MeAndMyHemi
Default 08 Quad Cab Blinker Craziness.... Help!
Here's the deal. Left blinker goes into fast click/ doesn't work. Bulb is fine. I checked. What's crazy is it does it occasionally. Hit the turn signal, it's fine for a moment, then it goes into fast click, or doesn't. Doesn't seem to be a corelation to position of steering wheel or pressure on the turn signal.
It's only 7 months old by the wway. Any thoughts?
Old Jan 14, 2009 | 01:54 PM
Hoss356's Avatar
Hoss356
Probably an intermittent short in the wiring or a bad contact?
Old Jan 14, 2009 | 02:35 PM
bolang's Avatar
bolang
you need to pull and replace both front and rear turn signal bulbs.that will fix your problem.loose solder inside bulbs is the issue.have seen this many times.
Old Jan 14, 2009 | 04:09 PM
MeAndMyHemi
That worked! You guys rock!!!
