how much boost can the hemi handle?
Old May 3, 2021 | 03:36 AM
  #21
Boostedrt's Avatar
Boostedrt
Originally Posted by bulletperformance
your going to blow seals and gaskets out the wazoo it can only take 2psi on stock gaskets and the internals will get annihilated with that much boost plus you will have to get different injectors and different coil system it is going to be alot more then just slapping a charger on..
so I dont agree on the gaskets and seals, I have a 2010 rt. Manual I've had boosted on 8lbs for the past 2 years and has not had any issues with seals and gaskets at all. Made 550whp at 6700ft uncorrected on the first tune then 600 after did a re tune on e85. I did however when installing the procharger upgrade the cam and valve springs as well as push rods but i used OEM gaskets for everything nothing multi layered from any performance stores. I know they arent the strongest motors but i do think they are really underestimated when it comes to what they can handle.
Old May 3, 2021 | 09:16 AM
  #22
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
