disabling ignition chip
Old Jan 17, 2009 | 04:08 PM
brettsss's Avatar
brettsss
Default disabling ignition chip
I have a 2007 dodge 1500 4X4 4.7 L that is used for work. I need to make several copies of ignition keys for employees but can not afford the $200.00 plus cost per key. Is there a way to disable the computer chip in the key or truck that will allow me to use a regular key?
Old Jan 18, 2009 | 07:10 AM
kevin mccune's Avatar
kevin mccune
somebody told me you can attach a key with chip near the switch on a Ford and a cheap cut key would work the ignition .Dont know if it would work on a Dodge or not- plus there are security issues( sure is hard to get a simple vehicle nowadays)-Kevin
Old Jan 18, 2009 | 05:33 PM
eaglestorm's Avatar
eaglestorm
You can get jut the screem key with out the fob and have it programed there are even aftermarket key that have the chip last I heared they cost about 65 bucks each compaired to the key with fob. we do have the key with sep fob for the cop cars the dodge key without the fob is gray and has a thick head for the chip
Old Jan 22, 2009 | 11:48 PM
Hillbilly1964's Avatar
Hillbilly1964
Bypassing the security system is a good way to get the insurance canceled. The tan head key with a 's' on the blade is the way to go.
Old Feb 8, 2009 | 08:09 PM
divetruck's Avatar
divetruck
A good automotive locksmith should be able to do this cheaper than the dealer. It is not dealer only.
Old Feb 8, 2009 | 08:42 PM
dodgeorgethit's Avatar
dodgeorgethit
Cheap on ebay
Old Feb 8, 2009 | 09:17 PM
traker1001's Avatar
traker1001
The dealer can disable the Pass Key system. This is very commonly done with Gov't and large corporate cars and trucks.
Old Feb 8, 2009 | 10:09 PM
My1st-Hemi's Avatar
My1st-Hemi
The keys on eBay are in fact cheap, but then you have to pay a locksmith $40 or more just to cut your key for you; then you have to program it or pay someone to program it for you. After a little research, I opted not to buy a key off of eBay. I went to my local locksmith and paid $40 for his key that he cut and programmed for me. Of course, this is the gray key without the fob.
Old Feb 8, 2009 | 10:26 PM
codiac's Avatar
codiac
If you've got 2 chipped keys already, buy the eBay ones. They were 10 bucks and the locksmith only cost me 2.50 to cut 2. Only difference, they don't have them Rams head on them.
The procedure to program keys in on here somewhere, or in the manual, but it requires 2 already to be programmed. There might be a limit on number of chipped keys the truck can remember.
