help replacing speaker on driver and passanger side doors?
Old Jan 21, 2009 | 07:45 PM
Steve180's Avatar
Steve180
Default help replacing speaker on driver and passanger side doors?
have a dodge ram 1500 need help taking the door panels off, etc.
Old Jan 21, 2009 | 07:47 PM
JoeHemi's Avatar
JoeHemi
what year truck? my 04 you just take off the door handle (10mm bolt i think, or 8mm) and then lift up. Dont pull it too far off as you need to unhook the speaker and the electric lock clips.
Old Jan 21, 2009 | 07:57 PM
nickahern1's Avatar
nickahern1
and if its a 06+ ram there is 2 phillips head screws on bottom of door. one up near where the mirror is ( but on the inside obviously) one torx bit in the handle ( have to take handle off) then youll see the last phillips head behind handle. lift up over door lock rod and then pull out ( be carefull not to pull to hard as the wires to the doorlock/window up/down switch are short.
